Defining Context-Sensitive Zones
A context-sensitive zone allows you to associate a zone with a specific user-interface transaction. A context-sensitive zone appears at the top of the Dashboard when a user accesses a page for which the zone is specified as the context. For example, when viewing a business object, additional zones are visible that are specific to the business object page.
CAUTION:
Make sure that the zone is appropriate for the transaction on which you are specifying it. For example, if your zone requires a business object ID as one of its keys, it should not be displayed on the To Do entry transaction.
Select  >  to maintain context-sensitive zones.
Description of Page
The Navigation Key is a unique identifier of a tab page within the system. Owner indicates if this navigation key is owned by the base product or by your implementation (Customer Modification).
CAUTION:
Important! When introducing a new context sensitive zone, carefully consider its naming convention. Refer to
System Data Naming Convention for more information.
 The grid contains the list of context-sensitive zones and the sequence in which they appear in the dashboard for the selected navigation key. The grid contains the following fields:
• Zone is the name of the zone to display in the Dashboard.
• Sequence is the sequence in which the zone is displayed (if multiple context-sensitive zones are defined).
• Owner indicates if this context sensitive zone is owned by the base product or by your implementation (Customer Modification).
Where Used
A context-sensitive zone displays at the top of the Dashboard whenever a user accesses the transaction for with the zone is specified.
Parent topic
