Defining Portals
This portal is used to view and maintain the configuration of portals. An implementation may define their own portals or may override some of the settings for base product provided portals.
You can access the portal from the >  > . You are brought to a query portal with options for searching for a specific record. Once a portal record has been selected you are brought to the maintenance portal to view and maintain the selected record.
The following zones may appear as part of the portal's Main tab page
• Portal. This zone provides information about the selected portal definition.
• Options. This zone lists various configuration options for the selected portal record.
• Tabs. This zone lists other tab portals if any are configured for a standalone portal. This zone is only visible when such tabs exist for the current standalone portal.
• Context Sensitive Zones. This zone lists context sensitive zones that appear on the dashboard when this portal is displayed . This zone is only visible when such zones exist for the current standalone portal.
Parent topic
