Defining Zones
This portal is used to view and maintain the configuration of a zone. Implementations may define custom zones or override the descriptions and some parameter values for base product zones.
You can access the portal from the >  > . You are brought to a query portal with options for searching for a specific zone. Once a zone record has been selected you are brought to the maintenance portal to view and maintain the selected record.
The following zones may appear as part of the portal's Main tab page
• Zone. This zone provides general information about the selected zone.
• Query Options. This zone maintains the list of query options for a Multi-Query zone. The zone is only visible for Multi-Query zones.
• Filters. This zone maintains various zone parameters that handle filtering options for a data explorer zone. The zone is only visible for data explorer zones.
• General Parameters. This zone maintains various general purpose zone parameters for a data explorer zone.
• SQLs. This zone maintains individual SQLs and their related parameters. The zone is only visible for data explorer zones.
• SQL Configuration. This zone maintains all the zone parameters related to a specific data explorer SQL. The zone is only visible when a specific SQL is broadcast from the SQLs zone.
The following zones may appear as part of the portal's References tab page
• Zone References. This zone list various configuration entities referencing the current zone.
Parent topic
