Insight Groups
An insight group may be used to include several
insight types together onto a single map. When defining an insight group, you configure the visual structures that the insight group should include. Only insight types for the configured visual structure are available.
Insight Class
Each insight group must reference a unique insight class. The insight class is defined using a lookup. The lookup field is INSIGHT_CLASS_FLG. Your product may already deliver base values for insight class. To display insights in a user interface your UI map would include the ou-insights web component. This component includes syntax to reference an insight class and the logic will find the insight group for that class and render all the insight types linked to that group.
Because the insight class is used as the reference in the web component rather than the insight group, it allows your product to supply base logic to show insight group information in a base delivered user interface. The base logic defines an insight class in base and references it on a base UI map. Your implementation can then define the insight group for this insight class and choose the insight types that should be rendered in that map. Refer to your specific product documentation to find out if there are any base delivered insight classes.
If your implementation identifies a new use case where one ore more insight types should be displayed, once the insight types are configured, do the following:
• Define a new Insight Class lookup value.
• Define an Insight Group that references this insight class and configure the appropriate insight types.
• Include the appropriate
web component in the map for your user interface where you wish to display this information.
Parent topic
