Restoring an Object
You can restore an older version of either a current object or a deleted object.
An object must be checked in before an older version can be restored.
To restore an object:
1. Go to the Revision History portal for the object.
If the object was deleted you must search for it by going to > > .
2. Select the desired entity by clicking the hyperlink in the Details column.
3. Locate the row in the version history that has the version that you want to restore and click Restore.
4. In the confirmation dialog box select OK to confirm the action or Cancel to return to the object page.
Parent topic
