Script - Step
Use this page to add or update a script's steps. Open this page using > > and then navigate to the Step tab.
Note:Time saver. You can navigate to a step by clicking on the respective node in the tree on the Main tab.
Description of Page
The
Steps accordion contains an entry for every step linked to the script. When a script is initially displayed, its steps are collapsed. To see a step's details, simply click on the step's summary bar. You can re-click the bar to collapse the step's details. Please see
accordions for the details of other features you can use to save time.
Select the
Step Type that corresponds with the step. Refer to
How To Set Up Each Step Type for an overview of the step types.
CAUTION:
The Step Type affects what you can enter on other parts of this page. The remainder of this section is devoted to those fields that can be entered regardless of Step Type. The subtopics that follow describe those fields whose entry is contingent on the Step Type.
Step Sequence defines the relative position of this step in respect of the other steps. The position is important because it defines the order in which the step is executed. You should only change a Step Sequence if you need to reposition this step. But take care; if you change the Step Sequence and the step is referenced on other steps, you'll have to change all of the referencing steps.
Note:Leave gaps in the sequence numbers. Make sure you leave space between sequence numbers so that you can add new steps between existing ones in the future. If you run out of space, you can use the Renumber button to renumber all of the steps. This will renumber the script's steps by 10 and change all related references accordingly.
Display Step is only enabled on BPA scripts for step types that typically don't cause information to be displayed in the
script area (i.e., step types like
Conditional Branch,
Go to a step,
Height, etc). If you turn on this switch, information about the step is displayed in the script area to help you debug the script.
CAUTION:
Remember to turn this switch off when you're ready to let users use this script.
If Display Step is turned on and the step has Text, this information will be displayed in the script area. If Display Step is turned on and the step does not have Text, a system-generated messages describing what the step does is displayed in the script area.
Display Icon controls the
icon that prefixes the
Text that's displayed in the script area. Using an icon on a step is optional. This field is only applicable to BPA scripts.
Text is the information that displays in the
script area when the step executes. You need only define text for steps that cause something to display in the script area.
The other fields on this page are dependent on the Step Type. The topics that follow briefly describe each step type's fields and provide additional information about steps.
Click on the
View Script Schema hyperlink to view the script's data areas. Doing this opens the
schema viewer window.
The
View Script As Text hyperlink appears for server-based scripts only. Click this link to view the internal scripting commands in a separate window. The presented script syntax is valid within
edit data steps.
Parent topic
