Adding Attachments
Common attachments may be added from the attachments portal (or via the standard menu path). In addition, your product may support attachments associated with specific records (“entity owned attachments”) which may also provide the capability to add attachments.
In both cases, when adding an attachment, you are prompted for the file to upload. Once the file is chose, the system determines the appropriate business object to associate with the attachment based on the file extension. Typically one and only one business object is found at which point you are prompted to provide the Attachment Name. (Your specific product may also require additional information at this time). Fill in the details and save.
Please note the following:
• If no business object is found for the uploaded file’s file type, an error is issued. This type of file is not currently supported as an attachment.
• If multiple business objects are found, the user must choose the appropriate one. This should be rare.
Parent topic
