Defining Data Export Control
This portal is used to maintain Data Export Control records. These records capture your organization’s export settings and current export state for a selected maintenance object. For a generalized export it keeps an indication as to whether the initial export for the maintenance object has been completed or not and whether changes made to the maintenance should be tracked and exported on an ongoing basis. For a specialized data export it keeps the date/time through which data was exported.
You can access the portal from the > > You are brought to a query portal with options for searching for a specific record. Once a data export control record has been selected you are brought to the maintenance portal to view and maintain the selected record.
The Data Export Control zone provides information about the selected record.
Parent topic
