Business Services
A business service is used to expose a back-end service so that it may be invoked by a script or a zone or a map to retrieve information or perform functions, depending on the related service.
As with the business object, the business service's interface to the internal service is defined using its schema. The schema maps the business service's elements to the corresponding elements in the internal service program's XML document. Just as a business object can simplify the schema of its maintenance object by only defining elements that it needs and “flattening” entries in a child collection to be defined as a singular element, a business service schema may simplify its service XML in a similar way.
Fastpath:
Refer to
Schema Syntax for a complete list of the XML nodes and attributes available to you when you construct a schema.
 Inbound web services and
 scripts support interaction with business services. You can also invoke a business service from a Java class.
Parent topic
