Switch Language Zone
The Switch Language zone is used to switch the application's language. Only languages that are supported by your implementation will appear.
To switch the application's language, choose the desired language and press the Refresh button.
If your implementation uses a single language, you should suppress this zone by
 not granting security rights to the zone's application service.
 Parent topic
