User - Characteristics
Select  >  >  >  and navigate to the Characteristics tab to define characteristic values for the user. You cannot modify this page if you accessed it through My Preferences.
Description of Page
Use the characteristics grid to capture additional information about the user.
You can only choose
Characteristic Types defined as permissible for the user record. Refer to
 Setting Up Characteristic Types & Their Values for more information.
Enter a valid Characteristic Value for the selected characteristic type. You may enter more than one characteristic row for the same characteristic type, each associated with a unique Sequence number. If not specified, the system defaults it to the next sequence number for the characteristic type.
Parent topic
