To Do Entry
Refer to
Understanding To Do Processing for detailed explanations about many To Do entry features.
To view a To Do entry. Use  >  >  >  . You are brought to a query portal with options for searching for a To Do Entry. Note that some query options limit the results. Refer to the inline help for more information.
Note:Restricted by role. Any user may change Comments for any To Do Entry. In addition, any user may add user Log details. However, for all other changes and actions, you may only change To Do entries that are assigned to you or ones that are
Open and assigned to a role to which you belong. Refer to
 To Do Entries Reference A Role for more information about roles.
 Once a To Do Entry has been selected, you are brought to the maintenance portal to view and maintain the selected record.
The inline help provides information about several fields. The following points highlight information about some of the fields that may be visible.
If the To Do entry has non-complete
related entries an insight appears indicating the number of related entries. In addition, details about the related entries are shown in the Related To Do Entries zone.
If the To Do entry was
Created By a background process, information about that background process appears with a link allowing the user to drill into the batch run, if desired. Refer to
 To Dos Created for Object-Specific Error Conditions for more information.
If the To Do type is configured to
To Do Entries May Be Routed Out Of The System, the
Extract Info appears. If the extract process is pending, the information indicates that. Otherwise, if it has run, information about the background process appears with a link allowing the user to drill into the batch run, if desired.
The
Characteristics collection shows existing characteristics. This collection is maintained using the Edit action for users that are allowed to update this To Do entry. Refer to
To Do Entry Characteristics for more information.
Actions
This page has two special actions.
• Use the Forward to assign a To Do to another user or role. When a To Do is forwarded, a log entry indicates who forwarded the To Do, to whom it was forwarded, and the specified reason. The dialogue prompts for whether to send to a User or a Role. The search for User includes information about the number of To Do entries already assigned to this user. When choosing a User, confirm the correct Role. The Details provided are captured in the log entry.
• Send Back is only applicable if the Sent By user is populated. When a To Do is sent back, a log entry is created that indicates when the To Do was sent back and by whom. If the To Do is Open, this dialogue allows you to send it back to a different role. If the To Do is assigned to you, the dialogue allows you to re-assign the To Do to the person who assigned it to you. The Details provided are captured in the log entry.
If the To Do has
related To Do entries, this zone appears with information about the related entries. Use this
Edit hyperlink to navigate to the
To Do Search query to perform actions on the related entries.
Parent topic
