To Do Priority
A To Do entry is associated with a priority level representing its processing order compared to other entries. Refer to
 The Priority Of A To Do Entry for more information on how an entry's priority is initially assigned and how it may be automatically updated by the system.
A user may manually override a To Do entry's priority at any time. Once overridden, automatic recalculation of the priority is no longer performed so as not to override the value explicitly set by the user. Manual overrides of a To Do entry's priority are recorded on the
To Do entry log.
Only users that are currently assigned to a Being Worked On To Do entry or ones that are valid for the role of an Open To Do entry may manually change the priority.
Parent topic
