Maintaining Asset Locations
You use the Asset Location portal is used to search for asset locations.
You can access the
Asset Location portal from
Menu > Asset Management > Asset Location. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the
Service Point portal to view and maintain the selected record.
In Oracle Utilities Customer To Meter, asset locations are created and/or updated when a service point is created and/or updated. If the service point has a contact associated with it, a corresponding contact will be created for the asset location. See
About Contacts and
Maintaining Contacts for more information about creating and maintaining contacts used with asset locations.
Parent topic
