Maintaining Service History
You use the Service History portal is used to display and maintain service history records.
You can access the portal from Menu > Asset Management > Service History. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
• Service History: This zone displays the basic attributes of the service history record.
Parent topic
