Maintaining Specifications
You use the Specification portal is used to display and maintain specifications.
You can access the portal by selecting Menu, then Asset Management, then Specification. You are brought to a query portal with options for searching. Once your record has been selected you are brought to the maintenance portal to view and maintain the selected record.
• Specification: This zone displays the basic attributes of the specification.
• Specification Assets: This zone displays a list of assets that reference the specification.
Parent topic
