How Auditing Works
You enable auditing on a table in the table's meta-data by specifying the name of the table in which to insert the audit information (the audit table) and the name of the program responsible for inserting the data (the audit trail insert program). Then you define the fields you want to audit by turning on each field's audit switch in the table's field meta-data. You can audit fields for delete, insert and update actions.
Once auditing is enabled for fields in a table, the respective row maintenance program for the table assembles the list of changed fields and calls the audit trail insert program. If any of the changed fields are marked for audit, the audit program inserts audit rows into the audit table.
Customizing Audit Information. You may
want to maintain audit information other than what is described in Captured Information or you may want to maintain it in a
different format. For example, you may want to maintain audit information
for an entire row instead of a field. If so, your implementation team
can use the base audit program and base audit tables as examples when
creating your own audit trail insert program and audit table structures.
