To Do Type - To Do Characteristics
The To Do Characteristics page defines characteristics that can be defined for To Do entries of this type. The characteristic types for characteristics that are linked to the To Do entry as a result of a pre-creation algorithm do not need to be defined here.
To maintain this information, select To Do Characteristics page.
and navigate to theTurn on the Required switch if the Characteristic Type must be defined on To Do entries of this type.
Enter a Characteristic Value to use as the default for a given Characteristic Type when the Default switch is turned on. Use Sequence to control the order in which characteristics are defaulted.
