SCADA Component
The Oracle Utilities Network Management System MultiSpeak Adapter's SCADA component has the capability of interacting with SCADA systems having a MultiSpeak-compatible interface.
The following functionality is available:
Receiving device status updates from SCADA system
Receiving analog and digital measurement updates from SCADA system
Mapping of SCADA quality codes (applies to status and measurement updates)
Receiving tag information from SCADA system
Receiving alarm information from SCADA system
Sending control request to SCADA system to operate devices and place/remove tags
Sending device status information to SCADA system
Sending NMS tags and other conditions to SCADA system
Dynamic configuration of the mapping between SCADA points and NMS device/attribute pairs
Display integration between NMS and SCADA system
A single instance of the adapter is capable of communicating with multiple SCADA systems. Several communication links can be configured for each SCADA system. If the currently active link fails, the adapter will automatically switch to the next link.
