Error Code | Error Description | Notes |
LP-001 | Too many fields | Expect 8 fields, 7 commas |
LP-002 | Too few fields | Expect 8 fields, 7 commas |
LP-003 | Invalid day type | The day type specified is not valid |
LP-004 | Invalid hour value | Should be integer type |
LP-005 | Invalid hour value | Should be 0 through 23 |
LP-006 | Invalid KW value | Should be floating type |
LP-007 | Invalid KVAR value | Should be floating type |
LP-008 | Duplicate Record | Duplicated hourly record found |
LP-009 | Invalid KVA rating or utilization factor | These values should be present in table pf_loads |
LP-010 | Transformer loading exceeds the rating based on specified threshold. | The threshold can be configured in the SRS rules, currently set to 200% |
LP-011 | Invalid Weather Zone | The weather zone associated to the load could not be located in the configuration. Please validate table PF_WEATHER_ZONE to ensure this zone is added properly. |
LP-012 | Invalid temperature value should be floating type. | Should be floating type. |
LP-013 | Load is mapped to a zone but the zone does not appear to be a valid weather zone. | A zone was configured for the load but this zone does not appear to be configured as a weather zone. It is instead setup for something else like an individual DER forecast or Demand Response Group. |
LP-014 | A Null Weather Zone value was provided. | The load was configured with a null weather zone value. Validate the zone associated to the load is present in table PF_WEATHER_ZONE and forecast date is present in table PF_WEATHER_ZONE_FORECAST. |
LP-015 | A Null kW value was provided | The CSV file contained a record that had a null value for kW. This data will not be processed and the sample counts will not be increased. This data will be thrown away and not loaded. |
NM-001 | Dist Gen data could not be located | Dist Gen information could not be located for a dist gen associated with a net metered profile. |
NM-002 | Dist Gen has an invalid power source | Power source is invalid for a dist gen associated with a net metered profile. |
NM-003 | Dist Gen Invalid Weather Zone | Weather zone is invalid for a dist gen associated with a net metered profile. |
NM-004 | Dist Gen Profile is invalid | The profile associated to the dist gen could not be located. This is needed to perform net metered profile processing. |
NM-005 | Dist Gen output exceeds the connected transformers rating based on a specified threshold. | This rule uses the same SRS rule as used for LP-010 and can be configured in the SRS rules. The NM-005 error is looking purely at Dist Gen output in comparison to the rating of the transformer excluding any loading information. |
