Prerequisites
The Oracle Utilities Network Management System Software Development Kit requires the following:
GNU Make
Apache Ant
Java SE Development Kit
Java EE Software Development Kit
Verify that your .nmsrc was generated using the $NMS_BASE/bin/nms-env-config script or based on the .nmsrc.template file in the $NMS_BASE/templates directory. The nms-env-config script can be used over and over again to review and/or update NMS specific environment variable configuration. Make sure the $NMS_BUILD env variable is set to $NMS_BASE/build template from $NMS_BASE/templates/nmsrc.template and that the environment variable $NMS_BUILD is set to $NMS_BASE/build.
