Power Flow Rules
Oracle Utilities Network Management System Distribution Management applications use srs_rules parameters with a SET_NAME of ‘PFS’ to configure what kind of data sets are used and how the application results are computed and displayed.
To view and edit Power Flow Rules, use the Event Management Rules tab in the Configuration Assistant. Expand the Power Flow Related Rule item in the left panel to display the rule categories.
