Command | Arguments | Description |
debug FLISR | <N> | Sets the debug level: 0 = off 1 = demand scan & timing info 2 = Trace 3 = Detailed Information regarding solution 4 = Full debug |
flisr kva_tolerance | <N> | Sets the capacity tolerance to allow. Where <N> is the new tolerance in kVA |
flisr base_flows | Outputs the base conductor flow information | |
flisr ties | Outputs the ties (open) point summary | |
flisr alarms | Forces a check for the Fault Location, Isolation, and Service Restoration disabled device alarms | |
flisr check | ON/OFF | Toggle Fault Location, Isolation, and Service Restoration check mode on/off |
flisr reload | Reload measurement configuration | |
flisr dump | Write internal data structures into log |
