SRS Rules
The following SRS Rules must be configured when using the FLEX SCADA module:
scadaFepInterface
Defines the SCADA interface to use. Currently only supports one interface.
This must be set to LecInterface
scadaFepTlsCert
If encrypted communication is being deployed then this SRS must be set and defines the path or ID of the TLS Certificate for encrypting communication between NMS and the Front End Processor.
RT_IGNORE_TIMESTAMP
Defines whether changes with older timestamps should be discarded. If set to Yes then the changes will not be discarded.
This rule must be set to Yes
nmsScadaEnabled
Controls whether the FLEX SCADA module is enabled or not.
