Variable | Description |
NMS_SMTP_SERVER | This is the fully qualified network hostname of the mail server. |
NMS_DOMAIN_SUFFIX | Domain Suffix – This value should be a valid domain such as "oracle.com". This value is used in constructing the domain portion of the "From" field for all outbound messages. This field is also used during SMTP communication between the CORBA gateway and the mail server. It is important to set this to a valid domain, as some SMTP servers will verify that the domain exists and is real. If the server does not believe that the domain is legitimate, the email message may be discarded |
Column | Description |
MSG_SUBJECT_ID | Primary key. Assigned from the MYC_MSG_SUBJECTS_SEQ database sequence. |
MESSAGE_TYPE_ID | Notification message type. See database table MYC_MESSAGE_TYPES for the list of valid notification message types. |
TRIGGER_CODE | Notification trigger code. Valid values: 1 - Outage started/in-progress 2 - Outage restored 3 - Planned outage is scheduled 4 - Outage is canceled 5- ERT has been updated for an outage 6 - Storm started 7 - Storm ended 8 - Storm has been updated 9 - Crew action has occurred for an outage Note: The list of applicable trigger codes differs depending on the notification message type. |
PLANNED | Planned/unplanned outage notification. Valid values: Y - planned N - unplanned |
EMAIL_SUBJECT | Subject line for email notification messages. |
PAGER_SUBJECT | Subject line for text/SMS notification messages. |
Name | Description |
CTRLZONE1 | Name of the level 1 control zone |
CTRLZONE2 | Name of the level 2 control zone |
CTRLZONE3 | Name of the level 3 control zone |
CTRLZONE4 | Name of the level 4 control zone |
CTRLZONE5 | Name of the level 5 control zone |
CTRLZONE6 | Name of the level 6 control zone |
EVENTIDX | Outage event index |
EXTERNALID | Outage external id |
DEVICEALIAS | Outage device alias |
DEVICECLASSNAME | Outage device class name |
CUSTOMERSOUT | Number of customers affected by the outage (system-calculated value) |
USERCUSTOUT | Number of customers affected by the outage (user-provided value) |
CRITICALCUSTOMERSOUT | Number of critical customers affected by the outage |
WCUSTOUT | Weighted count of customers affected by the outage |
SHEETNUM | Switching sheet number |
RELATEDEVENT | Event index of the related event |
RELATEDTYPE | Relation type code. Possible values: N - nested M - momentary P - partial restoration L - lead event of partial restoration M - manual S - switching |
