Model Build System Data File
The Model Build System Data File (system.dat.model_build) configures services for Model Build/Configuration operations. It is formatted the same as system.dat.
The system.dat.model_build starts only SMService, DBService, ODService, and MBService. These services are generally executed from configuration scripts, such as nms‑setup, which require that some services be running to access the database and object classes.
