In Construction Pending / Device Decommissioning (ICP)
Oracle Utilities Network Management System supports the modeling and visualization of devices that are in-construction as well as devices that are marked for decommissioning. ICP can be used for commissioning new construction (such as road widening) and should not be used for nominal-state changes (such as feeder load balancing).
Device Lifecycles
In a GIS system, a device will fall in to one of four possible states:
Model Requirements for ICP
In order to use In Construction Pending (ICP), each affected device must have an additional value listed in their physical_properties entry inside the import file, as shown below:
The model preprocessor calculates these values and writes them out into import files.
Note: Model Extractors must be modified to not filter out devices in the "Install" state.
Model Builds and Commissioned/Decommissioned Devices
The Commissioning Tool moves devices between "Not Commissioned" and "Commissioned" as well as "Not Decommissioned" and "Decommissioned".
If an operator commissions a device, marked as Construction, a model build will not reset the commissioning state (i.e., Subsequent model builds will not undo changes made by the Commissioning Tool).
Effect of ICP Devices on Network Topology
Devices affect the network’s topology as follows:
ICP Device Symbology
The Viewer will hide certain ICP-marked devices and display certain ICP devices with additional symbology.
Note: See "Understanding the Viewer" in the Oracle Utilities Network Management SystemUser Guide for more information on ICP symbology and how to use the Commissioning Tool.
Troubleshooting Issues with ICP Device Symbology
If you notice that some pending construction and pending decommission objects are missing conditions and are not hiding correctly with the Hide/Display option in the Viewer, you can run DBCleanup with the -fixICP option.
To see the objects that are missing conditions:
DBCleanup -fixICP -showMe
To add the conditions:
DBCleanup -fixICP
DDService is required to be running. No services need to be stopped or restarted when using this option.
You can run DBCleanup -fixICP -skipMBSCheck if you are only performing this ICP cleanup routine and no other model-related routines.
Note: running DBCleanup -fixAll does not run the -fixICP option.
