Client Development Installation Overview
Follow these steps to install, build, and deploy the Oracle Network Management System Operations Mobile Application:
1. Use the table in the Hardware Requirements section to identify the supported build environment platforms.
2. Review and prepare for the download and installation of required Oracle and third-party software as described in the Prerequisite Software section.
3. Install the third-party software.
4. Unzip the Oracle Network Management System Operations Mobile Application project files from the $NMS_BASE/sdk/OMA2.zip file to your build environment system.
5. Install the Node.JS from https://nodejs.org. You will need version 14.17.3 or higher.
6. Build the Oracle Network Management Systems Operations Mobile App.
7. Run the built client using the browser to test your built application.
