Editing and Renaming Filters
To edit a filter, right-click the filter and select Edit Filter… from the context menu (or double-click the filter). In the Edit Filter dialog box, you can edit the filter criteria or rename the filter. You can also rename filters and folders by right-clicking and choosing Rename... or by selecting them and pressing F2.
