Moving and Copying Filters and Folders
Filters are organized in folders. They can be copied or moved using drag and drop, or via items on the right-click menu.
• To move a filter to a different folder, select the filter, right-click, select Cut, and then Paste in the desired location.
• To create a copy of a filter and place it in a different folder, right-click, select Copy and then Paste in the desired location.
• To create a duplicate of a filter, right click and select Duplicate. Enter a new name, optionally change the filter criteria, and then click OK.
• To delete a filter, right-click and select Delete.
Moving, Copying, & Deleting Folders
• To move a folder (and its contents) to a different folder, right-click, select Cut from the context menu, and then Paste in the desired location.
• To copy a folder (and its contents) to a different folder, right-click, select Copy, and then Paste in the desired location.
• To delete a folder (and its contents), right-click and select Delete.
