General Accessible Mode selection Windows The currently open windows are saved and reopened when you login. This feature is restricted to the following windows: • Condition Summary • Crew Actions • Viewers (each Viewer is saved separately) • Service Alarms • SCADA Summary • Work Agendas (each Work Agenda is saved separately) • Table Attributes • Column widths • Column ordering • Locked columns • Current sort • Current filter | Viewer Settings • Unload on Focus • Fixed Size • Search Type • Search Case • Search Max Results • Spatial Landbase • Declutter • Predicted Highlight Enable • Pipe State Highlight Filters • Size and collapsed state of the Filter side panes • Filter folder collapsed/expanded state • Selected filter |
