Restoring to Default Preferences
To restore to the default environment settings, select Restore Preferences from the User menu's Manage Preferences submenu, which will open a dialog box with a list of user preference categories that may be restored:
• Table Sort Definitions
• Table Layouts
• Font Size
• All Other Preferences
Select the categories that you want to restore and click OK. The restored environment settings will take effect when you next log in.
If you have Administration permissions (having access to the
Configuration Assistant), you can use the
Restore Site‑wide Preferences option in the
Manage Preferences submenu to restore preferences for all users of the user type that you logged in as (for example, Full Operations).
Managing Your Workspace Layout
You can save and reload the layout of NMS tools as a
Workspace Layout. Each Workspace Layout stores the size and position of your open windows and frames (see
“Creating Window Frames” for information on Frames).
You can save multiple workspace layouts. This is useful when logging in at desks with different screen configurations. When you log in to Web Workspace, you have the option of choosing a workspace layout to load.
