Trace Type | Description |
To Source | Traces from the selected asset to its source. |
All Connected | Traces from the selected asset to all connected assets, stopping only at sources. |
To Valve | Traces from the selected asset to upstream and downstream valves. |
To Asset Class | Traces from the selected asset to an asset class. Click the Search button () to open the Select Class dialog box, which displays a tree list of device classes. Multiple device classes can be chosen by holding down the CTRL key when selecting additional classes. After making your selection, click the OK button to close the dialog box. |
To Closed Points | Traces from the selected asset to all directly-connected closed points on the pressure zone. |
To Nominally Closed Points | Traces from the selected asset to all directly connected nominally closed points on the pressure zone. |
