To commission or decommission sets of assets, perform the following steps:
1. In the Viewer, load the pending asset changes you wish to modify. You can select multiple assets.
2. Enable the Show Pending Assets option in the Hide/Display dialog box.
3. Switch to study mode if you don't want to affect the real-time model.
4. Select Commissioning Tool... from the Viewer's Actions menu. Selected assets pending approval are listed in the Waiting for Approval pane.
5. Select the assets you want to commission or decommission, then click the Approve () button.
Notes:
• Assets being decommissioned are no longer part of the model and are immediately colored as disconnected.
• Commissioned assets immediately become part of the model and connections are recalculated (that is, a newly commissioned asset attached to a supply will color as supplied).
