Notes Dialog Box
The Notes dialog box displays the following fields and buttons:
Fields
The Notes pane contains a table that lists existing notes.
The Edit Log pane contains a table that lists any previous versions of the selected note that exist.
The Note Text field displays the text of the selected note.
Buttons
The New button allows you to enter a new note.
The Edit button allows you to edit the text of the selected note.
The Delete button deletes the selected note.
The Help button launches online help for the Notes dialog box.
The Cancel button closes the Notes dialog box without saving changes.
