Menu Option | Description | Toolbar Icon |
Toggle Dockable Window | Changes a standalone window to a pane that may be moved or docked in another window or frame. See “Understanding Docked Panes and Standalone Window Tools” for more information on dockable and standalone windows. | -- |
Exit | Closes the window. | -- |
Sort Dialog... | Opens the Sort Dialog, allowing you to create, modify, apply, and save user-defined sorts. See “Using the Sort Dialog Box”. | -- |
Default | Applies the default sort. | -- |
Priority | Sort by alarm priority. | -- |
View... | Focuses the Viewer on the asset associated with the alarm. | |
Acknowledge | Acknowledges the selected alarms. | |
Silence | Silences the selected alarms. | |
Clear | Clears the selected alarms. | |
Silence all alarms... | Silences all alarms. |
Show all zones | Display alarms for all zones. | -- |
Show milliseconds | Toggles the display of time down to milliseconds. | -- |
Help | Opens the online help content. | -- |
