File Menu
Menu Option
Description
Toolbar Icon
Save
Saves the current event. If the event has already been completed, you are prompted to provide a reason for the update.
Print Tab...
Opens the Print Preview dialog box and allows you to print the current contents of the Job Actions tab.
Print All...
Opens the Print Preview dialog box and allows you to print the contents of all three Event Details tabs.
Exit
Exits Event Details. You must press the Save button before pressing the Exit button if you wish to save any revisions you may have made.
