Understanding the Damage Specifics Section
• Section Affected allows you to specific the section affected by the damage. You can select from a list or enter a value manually.
• Location allows you to specify the damage location. You can select from a list or enter a value manually.
• The Hazard check box indicates a hazardous situation.
• The Crew Types indicates the types of crews needed to repair the damage. Enter the number of each crew type.
• Comments contains any remarks associated with the damage specifics.
