Making a Crew Inactive
You can deactivate a crew to indicate that it is not available for work. You can only deactivate a crew if its status is Active or Off Shift and it has no current assignments.
To deactivate a crew, complete these steps:
1. In the Crew Actions window, select the active or off shift crew you want to deactivate.
2. Select Deactivate from the Actions menu. (In List view, you can also right-click the crew and then select Deactivate from the context menu.) The status changes to Inactive.
