Releasing a Crew from the Active Jobs Pane
1. From the Active Jobs table of the Crew Info window select the crew you want to release.
2. Click the Release Crew button. The following occurs:
• The crew is released from the event.
• The crew's active job information is removed from the Crew Info window.
• The crew button/row changes to white (if the crew is not assigned to another event).
