Bulk Crew Loading and Deleting (Administrative Users)
Administrative Users may perform a bulk import or deletion of crews and crew components (members and vehicles) using the nms‑load‑crews program. The program, which is run from a terminal, requires separate CSV files for crews, crew members, and vehicles.
nms‑load‑crews -crews filename
-members filename
-vehicles filename
[-add|-delete]
[-force]
[-status inactive|off-shift|on-shift]
[] optional parameter
Options
crews: Required. The crew file to import.
members: Required. The members file to import.
vehicles: Required. The vehicles file to import.
add|delete: Whether to add or delete the crews, members, and vehicles. The default is add, which is assumed if omitted.
status: Used with the -add option. Whether to add new crews as inactive, off-shift, or on-shift. Default: off-shift.
force: Used with the -delete option. Whether to force the deletion of active crews. Default: false.
Example
nms‑load‑crews -crews crews.csv -members members.csv -vehicles vehicles.csv
