Menu Option | Description |
Theme Selection Radio Buttons • Dark Theme • Light Theme | Theme selection allows you to choose whether the Web Call Entry uses a Dark Theme or a Light Theme. • The Dark Theme is generally better for low-lit conditions. • The Light Theme is generally better for well-lit conditions. |
Capitalize Field Labels | If selected, field labels will be displayed in All Caps (for example, NAME). If not selected, field labels will be displayed in title case (for example, Name). |
Toggle Accessible Mode | Changes settings to enable use with screen readers. Note: There are prerequisites to enabling accessible mode. Please see Appendix A‑Accessibility Features for information on enabling Accessible mode. |
Show Messages at Mouse Location | Sets the system to display popup confirmation and warning dialog boxes at your mouse pointer position. |
Smaller Font | Decreases the font size in text and icons. Repeat to further decrease the font size. |
Bigger Font | Increases the font size in text and icons. Repeat to further increase the font size. |
Reset Font | The application will reset the text and icons to use their default font size. |
Darken Watermarks | Make the watermarks more opaque. |
Lighten Watermarks | Make the watermarks more transparent. |
Show Watermarks | Allows you to toggle watermarks on or off. |
Alternate Row Coloring | When selected, displays data table rows in alternating colors. |
Capitalize Column Headings | Allows you to select whether column labels should be displayed in all capital letters (for example, STATUS) or in title case (for example, Status) |
Table Color Formatting Mode | Determines whether and how tables will display background coloring. Options • None: Tables will not contain color indicators for statuses. • Cells: Table cells will contain background colors based on the cell statuses. • Row: All cells in a table row will have the background color. |
Table Font Formatting Mode | Determines whether and how tables will display font formatting. Options • None: Conditional formatting related to font formatting are never shown. • Cells: Conditional formatting related to font formatting are applied only to the cells they were configured for. • Row: Conditional formatting related to font formatting are applied across the whole row. Where more than one formatting rule is applied, the highest priority rule is displayed. |
Save Preferences | Saves your preferences to the database so your settings are available wherever you log in. Note: Theme selection is saved to your user settings on the workstation since they are more likely influenced by the light in a location. |
Restore Preferences | Opens a dialog box that allows you to select the preferences to restore. |
Manage Site-wide Settings | Options • Update Site-wide Preferences: Users who have Administration permissions (having access to the Configuration Assistant) may log in as a different user type, configure, and save the default preferences for all users of the log in type. • Restore Site-wide Preferences: Users who have Administration permissions (having access to the Configuration Assistant) may restore the default preferences for the logged in user type to the original configuration. |
Storm Management Help | Opens the Online Help content for Storm Management. |
Email Log Files... | Gathers the environment's log files and attaches them to a new email message using your default email client. The log files can then be sent to your support team or contact for further analysis. |
Set Debug... | Launches the Set Debug dialog box allowing you to set debug on or off within your current environment. This is used for debugging and analysis purposes. See “Setting Debug” for more information. |
About Storm Management | Opens a dialog box that displays information regarding what version of the application is presently running, as well as version and other information about the Oracle Utilities Network Management System Web Gateway that the application is using. |
