Overriding the Estimates
To override the estimates to a default "global" ERT for the events in a zone, complete these steps:
1. Do one of the following:
Click the ERT Override button on the toolbar, or
Select the ERT Override... option from the System menu. The ERT Override dialog box opens.
2. Press the Add button to add a new row to the ERT Override table.
3. Click into the Zone cell of the new row, and then click the button on the right of the Zone field.
The Control Zone Selection dialog box opens.
4. Select the control zone whose estimates you wish to make inaccessible and click OK.
The Control Zone Selection dialog box closes.
The zone you selected populates the Zone field.
5. Select the ERT Override cell of the new row, and then click the date/time field.
6. Select a date and time for the new default ERT. Click OK on the Date/Time dialog box to close it.
7. Click out of the ERT Override cell and into a different cell to ensure the ERT Override time is saved.
8. Make sure the Publish Projections check box is checked.
9. Click OK. Storm Management's calculated estimates for that control zone are no longer displayed to other modules; the provided ERT Override value is displayed instead. The ERT Override dialog box closes.
