View Only Menus
There are three menus on the View Only Storm Management menu bar: System, Storm, and Help.
Menu
The options in the System menu are available in both storm and non-storm modes. The following table describes the System Menu options and associated toolbar icons.
Menu Option
Description
Toolbar Icon
Retrieve Update
Refreshes the window with the most recent information from the system.
Print All…
Opens the Print Preview dialog box, which allows you to print out the Summary Information pane, Storm Report pane, Storm Information pane (if present), Crew Information pane (if present), and status bar information from the current Storm Management window.
Print Crews…
Opens the Print Preview dialog box, which allows you to print out the Crew Information pane from the current Storm Management window. This option is only available in storm mode.
Storm Menu
The option in the Storm menu is only enabled when Storm Management is in storm mode for the selected control zone.
The following table describes the Storm Menu options.
Menu Option
Description
Toolbar Icon
Calculate Crews...
Opens the Calculate Crews dialog box, which is used to determine the approximate number of crews needed to complete assessment and repair by a specified date and time.
View Only Help Menu
The Help menu options are Storm Management Help, which opens the online help content for Storm Management, and About Storm Management, which displays information regarding the version of the application and the Web Gateway.
View Only Toolbar
The Storm Management toolbar provides a shortcut to many of the options available from the Storm Management menus.
The View Only Storm Management toolbar displays the following buttons.
The Retrieve Update button refreshes the window with the most recent information from the system. In most cases, the window refreshes itself on a periodic basis. But, if there are unsaved changes in the Storm Management window at the time the automatic refresh is due to occur, the window will not refresh. Instead, an alert appears in the status bar indicating that an update is available, and the Retrieve Update option must be invoked in order to refresh the window with the new update. This allows you to continue on with your changes and save them first before refreshing.
The Calculate Crews button opens the Calculate Crews dialog box, which is used to determine the approximate number of crews needed to complete assessment and repair by a specified date. This option is only available in storm mode.
