Menu Option | Description |
Theme Selection Radio Buttons • Dark Theme • Light Theme | Theme selection allows you to choose whether the Web Call Entry uses a Dark Theme or a Light Theme. • The Dark Theme is generally better for low-lit conditions. • The Light Theme is generally better for well-lit conditions. |
Capitalize Field Labels | If selected, field labels will be displayed in All Caps (for example, NAME). If not selected, field labels will be displayed in title case (for example, Name). |
Toggle Accessible Mode | Changes settings to enable use with screen readers. Note: There are prerequisites to enabling accessible mode. Please see Appendix A‑Accessibility Features for information on enabling Accessible mode. |
Show Messages at Mouse Location | Sets the system to display popup confirmation and warning dialog boxes at your mouse pointer position. |
Smaller Font | Decreases the font size in text and icons. Repeat to further decrease the font size. |
Bigger Font | Increases the font size in text and icons. Repeat to further increase the font size. |
Reset Font | The application will reset the text and icons to use their default font size. |
Darken Watermarks | Make the watermarks more opaque. |
Lighten Watermarks | Make the watermarks more transparent. |
Show Watermarks | Allows you to toggle watermarks on or off. |
Alternate Row Coloring | When selected, displays data table rows in alternating colors. |
Capitalize Column Headings | Allows you to select whether column labels should be displayed in all capital letters (for example, STATUS) or in title case (for example, Status) |
Table Color Formatting Mode | Determines whether and how tables will display background coloring. Options • None: Tables will not contain color indicators for statuses. • Cells: Table cells will contain background colors based on the cell statuses. • Row: All cells in a table row will have the background color. |
Table Font Formatting Mode | Determines whether and how tables will display font formatting. Options • None: Conditional formatting related to font formatting are never shown. • Cells: Conditional formatting related to font formatting are applied only to the cells they were configured for. • Row: Conditional formatting related to font formatting are applied across the whole row. Where more than one formatting rule is applied, the highest priority rule is displayed. |
Save Preferences | Saves your preferences to the database so your settings are available wherever you log in. Note: Theme selection is saved to your user settings on the workstation since they are more likely influenced by the light in a location. |
Restore Preferences | Opens a dialog box that allows you to select the preferences to restore. |
Manage Site-wide Settings | Options • Update Site-wide Preferences: Users who have Administration permissions (having access to the Configuration Assistant) may log in as a different user type, configure, and save the default preferences for all users of the log in type. • Restore Site-wide Preferences: Users who have Administration permissions (having access to the Configuration Assistant) may restore the default preferences for the logged in user type to the original configuration. |
