Adding Attributes
An attribute consists of a name and a value associated to an asset or customer. The attribute information can be displayed on notifications trigger by the associated asset.
1. Click the Attribute Manager tab on the Service Alert Administration Tool.
2. Click the Add button to bring up the Asset Search dialog box.
3. Enter into the Search Text field your search criteria.
4. Click the Search button. The search results are displayed in the table.
5. Select the desired asset from the table, and then click the OK button. The Asset Search dialog box disappears, and the Asset ID field is populated with the name of the selected asset.
6. Enter a descriptive name for the attribute into the Attribute Name field.
7. Enter a value for the attribute into the Attribute Value field.
8. Select/deselect the Active check box as desired.
9. Click the Save button to save the attribute.
