Menu Option | Description | Toolbar Icon |
Save | Saves changes made in the FEP Details tool. | |
Toggle Dockable Window | Changes a standalone window to a pane that may be moved or docked in another window or frame. See “Understanding Docked Panes and Standalone Window Tools” for more information on dockable and standalone windows. | -- |
Exit | Closes the SCADA Status window. | -- |
Disable FEP | Disables the selected FEP | |
Enable FEP | Enables the selected FEP | |
Add FEP | Creates a new FEP. | |
Remove FEP | Removes the selected FEP component. | |
Add Connection | Adds a new connection to the FEP. | |
Delete Connection | Deletes the current connection. | |
Enable Connection | Enables the selected FEP connection. | |
Disable Connection | Disables the selected FEP connection. | |
Change Active Connection | Changes the communications channel used to communicate to the FEP. Only visible if the FEP has multiple channels configured. |
FEP Details Help | Launches online help for FEP Details. | -- |
