Choosing the Analog Measurements to Display in the Viewer
An Administration user type may choose which measurement types (for example, water level, pressure, etc.) to display in the Viewer for a particular asset.
Note: Users must have Measurements selected in the Viewer Hide/Display dialog box to see any measurements.
To add or remove a measurement type for an asset, first load the Viewer map containing the device, then select the SCADA summary row for the asset measurement type, right-click, and choose one of the following options:
• Show Measurement in Viewer: Shows the selected measurement in the Viewer.
