Creating a Switching Sheet from a Template
After a switching template has been created and saved, you can use the template as the basis for another switching sheet.
To create a new planned sheet from a template:
1. From the File menu, select New, and then select Switching Sheet... The New Switching Sheet window is displayed.
2. From the Switching Sheet Types section at the top of the window, select Planned.
3. From the Pre-Created Switching Sheets list, select the template to use.
4. Click Create a Copy.
5. Edit the sheet as needed (see the instructions in the remainder of this guide) and save when you are done.
Switching Sheet Requests
Someone other than the person who prepares the switching sheet usually initiates switching sheet requests. The requester may be someone in the construction/maintenance department, while the preparer is typically an operations user assigned to look for and prepare new requests. Typically, the requester is a Switching Request user type.
