Adding Comment Steps
You can add comment steps that are not related to a specific asset or operation. To add a comment step, select the step after which you want the comment step inserted. Right-click this step, then choose Insert Blank Step from the context menu. With the row selected, click in the Operation column to enable adding a description of this step; the Details column is also available for descriptive text.
Note: You may enter text in the Operation, Details, Address, and/or Comments fields. You can also specify Date fields for the step. The other fields are populated automatically when you instruct and complete the step.
